Zum Hauptinhalt wechseln
PowerLead Puto PLD003 Back Buttons Replacement
Was du brauchst
  1. PowerLead Puto PLD003 Back Buttons Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Back Buttons Replacement: Schritt 2, Bild 1 von 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Back Buttons Replacement: Schritt 3, Bild 1 von 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Back Buttons Replacement: Schritt 4, Bild 1 von 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: Schritt 5, Bild 1 von 2 PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: Schritt 5, Bild 2 von 2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Back Buttons Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Back Buttons Replacement: Schritt 7, Bild 1 von 1
    • Apply pressure to the back panel, away from the camera to remove.
  8. PowerLead Puto PLD003 Back Buttons Replacement: Schritt 8, Bild 1 von 2 PowerLead Puto PLD003 Back Buttons Replacement: Schritt 8, Bild 2 von 2
    • Place the back panel so the buttons are facing down and the circuit board is facing up.
    • Remove the three 4 mm Phillips #1 screws holding the circuit board in place.
  9. PowerLead Puto PLD003 Back Buttons Replacement: Schritt 9, Bild 1 von 1
    • Set aside the circuit board.
    • These nubs are what is currently holding the buttons in place.
    • Carefully apply pressure and remove the set of buttons from the nubs.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 145
