Einleitung
This guide shows how to remove the side panel from the camera, how to remove the back panel, and how to replace the lens.
Was du brauchst
Rotate the camera so that the underside is facing up.
Remove the four 5 mm Phillips #1 screws.
Place the camera on a flat surface, with its underside facing you.
Gently pull up on the side panel to remove it from the camera.
Remove the three 4 mm Phillips #1 screws holding the weight.
Remove the weight.
Set aside back panel for now.
Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
Carefully apply pressure, away from the camera, to the screen to detach it from the body.
The white cord should still be connected to the body.
OPTIONAL: Remove the screen to make accessing the lens easier
Pull forward on the lens casing to remove it. The cord connecting the light to the motherboard should still be attached.
Push the lens out of the plastic casing from the back.
Insert new lens into the plastic casing.
