Zum Hauptinhalt wechseln
PowerLead Puto PLD003 Tripod Clip Replacement
Was du brauchst
  1. PowerLead Puto PLD003 Tripod Clip Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Tripod Clip Replacement: Schritt 2, Bild 1 von 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Tripod Clip Replacement: Schritt 3, Bild 1 von 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Tripod Clip Replacement: Schritt 4, Bild 1 von 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: Schritt 5, Bild 1 von 2 PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: Schritt 5, Bild 2 von 2
    • Apply pressure upwards to remove the tripod clip.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 137
