Zum Hauptinhalt wechseln
PowerShot G7 X Mark II Front Cover Replacement
Was du brauchst
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: Schritt 1, Bild 1 von 2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: Schritt 1, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: Schritt 2, Bild 1 von 2 PowerShot G7 X Mark II Front Cover Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove one 3mm screw on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: Schritt 4, Bild 1 von 2 PowerShot G7 X Mark II Front Cover Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: Schritt 5, Bild 1 von 2 PowerShot G7 X Mark II Front Cover Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the back cover off of the camera by hand, minding the ribbon cable attached to the camera body. If the cover does not detach, use a spudger to pry it off.
    • Use the spudger tool to open the ZIF connector attaching the ribbon cable to the camera body.
  6. PowerShot G7 X Mark II Front Cover Replacement: Schritt 6, Bild 1 von 2 PowerShot G7 X Mark II Front Cover Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: Schritt 7, Bild 1 von 2 PowerShot G7 X Mark II Front Cover Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: Schritt 8, Bild 1 von 3 PowerShot G7 X Mark II Front Cover Replacement: Schritt 8, Bild 2 von 3 PowerShot G7 X Mark II Front Cover Replacement: Schritt 8, Bild 3 von 3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: Schritt 9, Bild 1 von 2 PowerShot G7 X Mark II Front Cover Replacement: Schritt 9, Bild 2 von 2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: Schritt 10, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: Schritt 11, Bild 1 von 1
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: Schritt 12, Bild 1 von 1
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brandon
602 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 12-3, Eyestone Spring 2017 Mitglied von USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Mitglieder
Ein Kommentar
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 3,849
