Zum Hauptinhalt wechseln
PowerShot G7 X Mark II Top Cover Button Panel Replacement
Was du brauchst
  1. PowerShot G7 X Mark II Top Cover Button Panel Replacement, Top Cover Button Panel: Schritt 1, Bild 1 von 2 PowerShot G7 X Mark II Top Cover Button Panel Replacement, Top Cover Button Panel: Schritt 1, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 2, Bild 1 von 2 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove one 3mm screw on the left of the camera.
  4. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 4, Bild 1 von 2 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 5, Bild 1 von 2 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the back cover off of the camera by hand, minding the ribbon cable attached to the camera body. If the cover does not detach, use a spudger to pry it off.
    • Use the spudger tool to open the ZIF connector attaching the ribbon cable to the camera body.
  6. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 6, Bild 1 von 2 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 7, Bild 1 von 2 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 7, Bild 2 von 2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 8, Bild 1 von 3 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 8, Bild 2 von 3 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 8, Bild 3 von 3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 9, Bild 1 von 2 PowerShot G7 X Mark II Top Cover Button Panel Replacement: Schritt 9, Bild 2 von 2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Brandon
602 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 12-3, Eyestone Spring 2017 Mitglied von USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 14
Letzte 30 Tage: 60
Insgesamt: 2,578
