Zum Hauptinhalt wechseln
Prerequisite Exterior Housing Disassembly
Was du brauchst
  1. Prerequisite Exterior Housing Disassembly, Exterior Housing: Schritt 1, Bild 1 von 3 Prerequisite Exterior Housing Disassembly, Exterior Housing: Schritt 1, Bild 2 von 3 Prerequisite Exterior Housing Disassembly, Exterior Housing: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    iOpener
    $19.99
    Kaufen
    • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
    • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
    • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
Abschluss
To reassemble your device, apply double-sided tape or adhesive on the existing glue and fit the housing back on.
Jerrell
730 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 11-50, Amido Spring 2014 Mitglied von Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 295
