Was du brauchst
Remove the 9 screws on the plastic cover.
The Orange circle is the screw that holds the bracket in place . this screw does have a bushing on it DO NOT LOSE IT.
You're done ! from here you have complete access to extend mechanism and valve.
Fast fertig!
To reassemble your device, follow these instructions in reverse order. DON'T FORGET TO REPLACE ANY CUT ZIP TIES
Abschluss
