Zum Hauptinhalt wechseln
Presto 0282202 Disassembly
Was du brauchst
Angehängtes Dokument
  1. Presto 0282202 Disassembly, Presto 0282202 Disassembly: Schritt 1, Bild 1 von 3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: Schritt 1, Bild 2 von 3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: Schritt 1, Bild 3 von 3
    • Using the Phillips #2 screwdriver, remove the bottom two 25 mm screws off of the coffee percolator.
    • Lighty remove the bottom of the coffee percolator.
    • The wires will keep the two pieces connected.
  2. Presto 0282202 Disassembly: Schritt 2, Bild 1 von 3 Presto 0282202 Disassembly: Schritt 2, Bild 2 von 3 Presto 0282202 Disassembly: Schritt 2, Bild 3 von 3
    • Using the Phillips #2 screwdriver, remove the center 10.8 mm screw holding in the metal strip.
    • Take off the metal strip.
  3. Presto 0282202 Disassembly: Schritt 3, Bild 1 von 3 Presto 0282202 Disassembly: Schritt 3, Bild 2 von 3 Presto 0282202 Disassembly: Schritt 3, Bild 3 von 3
    • Lightly remove the right (bottom facing) thermal switch from its thermal paste.
    • Be careful as the thermal paste can be quite adhesive.
    • Using your small needle-nose pliers, take off the spade connectors connected to the thermal switch.
    • The easiest way to do this is to hold the thermal switch end with the pliers and tug the spade connector off.
  4. Presto 0282202 Disassembly: Schritt 4, Bild 1 von 3 Presto 0282202 Disassembly: Schritt 4, Bild 2 von 3 Presto 0282202 Disassembly: Schritt 4, Bild 3 von 3
    • Lightly remove the left (side facing) thermal switch from its thermal paste.
  5. Presto 0282202 Disassembly: Schritt 5, Bild 1 von 3 Presto 0282202 Disassembly: Schritt 5, Bild 2 von 3 Presto 0282202 Disassembly: Schritt 5, Bild 3 von 3
    • Remove the two spade connectors connected to the heating element.
    • The easiest way to do this is to hold the heating element end with the pliers and tug the spade connector off.
  6. Presto 0282202 Disassembly: Schritt 6, Bild 1 von 3 Presto 0282202 Disassembly: Schritt 6, Bild 2 von 3 Presto 0282202 Disassembly: Schritt 6, Bild 3 von 3
    • Remove the two spade connectors connected to the power connector.
    • The easiest way to do this is to hold the power connector end with the pliers and tug the spade connector off.
    • The final wire removed contains the small heating wire (the thick braided wire) and the signal light.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 820
