Einleitung
These instructions tell you how to take apart the Presto coffee maker and recover pieces such as two 4349806 Thermal Switches, a small heating wire, and some short wires with spade connectors. The deconstruction guide is easy to follow and only two tools are recommended, a Phillips #2 screwdriver and needle-nose pliers. The only hazard is to be careful of thermal paste when removing the Thermal Switches.
Was du brauchst
Angehängtes Dokument
Using the Phillips #2 screwdriver, remove the bottom two 25 mm screws off of the coffee percolator.
Lighty remove the bottom of the coffee percolator.
Using the Phillips #2 screwdriver, remove the center 10.8 mm screw holding in the metal strip.
Take off the metal strip.
Lightly remove the right (bottom facing) thermal switch from its thermal paste.
Using your small needle-nose pliers, take off the spade connectors connected to the thermal switch.
Lightly remove the left (side facing) thermal switch from its thermal paste.
Remove the two spade connectors connected to the heating element.
The easiest way to do this is to hold the heating element end with the pliers and tug the spade connector off.
Remove the two spade connectors connected to the power connector.
The easiest way to do this is to hold the power connector end with the pliers and tug the spade connector off.
The final wire removed contains the small heating wire (the thick braided wire) and the signal light.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
