Einleitung
This is a replacement guide for the chute. The chute helps guide the popcorn kernels to a bowl. This repair may be needed if the Chute has been broken over time. Be sure that you are only working on the Presto PopLite 04820 when it is unplugged and it has cooled down.
Was du brauchst
Remove the three 49 mm Phillips #2 screws.
Once you have removed the screws, remove the chute from popper base.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
