Zum Hauptinhalt wechseln
ProScan PLT7223G Battery Replacement
Was du brauchst
  1. ProScan PLT7223G Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Battery Replacement: Schritt 2, Bild 1 von 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
    • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
    • Soldering tool will get hot, handle with care.
  4. ProScan PLT7223G Battery Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to remove the black tape from the battery.
  5. ProScan PLT7223G Battery Replacement: Schritt 5, Bild 1 von 1
    • Using the flat end of a spudger, carefully separate the battery from the base of the device.
    • There is an adhesive holding the charger in place.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
what is the number of the replacement battery??
florcomm - Antwort
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 4,233
