Zum Hauptinhalt wechseln
ProScan PLT7223G Speakers Replacement
Was du brauchst
  1. ProScan PLT7223G Speakers Replacement, Speakers: Schritt 1, Bild 1 von 1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Speakers Replacement: Schritt 2, Bild 1 von 1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Speakers Replacement: Schritt 3, Bild 1 von 1
    • Pull back the protective tape from the two wires that connect the speakers to the motherboard.
  4. ProScan PLT7223G Speakers Replacement: Schritt 4, Bild 1 von 1
    • Use the soldering tool to remove speaker wires from motherboard.
    • Soldering tool will get hot, handle with care.
  5. ProScan PLT7223G Speakers Replacement: Schritt 5, Bild 1 von 2 ProScan PLT7223G Speakers Replacement: Schritt 5, Bild 2 von 2
    • If needed use a plastic opening tool to remove speaker from the speaker port on the tablet.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 304
