Einleitung
This guide will show how to remove the chassis from a Professional Series PS77401 toaster. The chassis may be damaged from a high height drop and may need replacing to allow even toasting. This guide is not a repair guide and requires a replacement toaster chassis.
Was du brauchst
Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
Locate the small circuit board attached to the base of the toaster.
To remove the circuit board, pull apart the two side tabs while releasing the middle tab simultaneously.
Pull the circuit board out of the slot.
Using a Phillips #2 screwdriver, remove the front two 8mm screws attaching the chassis to the base.
Flip the toaster around and proceed to remove the two remaining 8mm screws.
The toaster chassis should now only be connected to the base via wiring.
There are two phillips 8mm head screws holding the power cable to the base.
Remove these screws to release the power cable.
The following wires must be disconnected to be able to remove the chassis: Blue x2, White x2, Bronze x1
