Einleitung
A damaged spring can lead to issues with the toaster lever being fully locked in and released. When the lever is released it should be able to move freely in an upward direction. When the lever is being pushed down, it should move smoothly with slight resistance from the spring.
Was du brauchst
Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
Disconnect the bottom part of the damaged spring from the lever first.
Then disconnect the top part of the damaged spring from the chassis.
Attach the new spring in the same spots that the damaged spring was removed from.
