Zum Hauptinhalt wechseln
Professional Series PS77401 Toaster Solenoid Replacement
Was du brauchst
  1. Professional Series PS77401 Toaster Solenoid Replacement, Shell: Schritt 1, Bild 1 von 1
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Professional Series PS77401 Toaster Solenoid Replacement: Schritt 2, Bild 1 von 2 Professional Series PS77401 Toaster Solenoid Replacement: Schritt 2, Bild 2 von 2
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Professional Series PS77401 Toaster Solenoid Replacement: Schritt 3, Bild 1 von 3 Professional Series PS77401 Toaster Solenoid Replacement: Schritt 3, Bild 2 von 3 Professional Series PS77401 Toaster Solenoid Replacement: Schritt 3, Bild 3 von 3
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Professional Series PS77401 Toaster Solenoid Replacement: Schritt 4, Bild 1 von 2 Professional Series PS77401 Toaster Solenoid Replacement: Schritt 4, Bild 2 von 2
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
  5. Professional Series PS77401 Toaster Solenoid Replacement, Toaster Solenoid: Schritt 5, Bild 1 von 2 Professional Series PS77401 Toaster Solenoid Replacement, Toaster Solenoid: Schritt 5, Bild 2 von 2
    • Locate the metal knob protruding from the removed circuit board.
    • Remove the 10mm nut with an equally sized wrench and replace the now removable solenoid.
Abschluss
Cal Poly, Team 10-36, Maness Winter 2014 Mitglied von Cal Poly, Team 10-36, Maness Winter 2014
CPSU-MANESS-W14S10G36
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
That’s not a solenoid, that’s a potentiometer. And it’s probably soldered in so you would need to desolder it and solder in a new one, if you could find the part.
Stewart - Antwort
So. . . 1) Is this a potentiometer (variable resistor) or a solenoid? Seeing that it looks like it is connected to the toaster dial for depth of "toastness", it seems like a variable resistor (but I am not an expert), 2) Either way, what is the normal Ohm reading for this device? 3) How does one test the potentiometer? Can such test be done while installed in the toaster or must the variable resistor be completely removed from the toaster before testing testing?
Bob Gordon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,996
