Zum Hauptinhalt wechseln
Promowide SP1790 Charging Port Replacement
Was du brauchst
  1. Promowide SP1790 Charging Port Replacement, Battery Wire: Schritt 1, Bild 1 von 1
    • Locate the six screws on the back of the speaker.
  2. Promowide SP1790 Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Unscrew each of the six screws, then set them aside.
  3. Promowide SP1790 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the back cover of the speaker.
  4. Promowide SP1790 Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Place the speaker upside down.
    • Remove the battery cover located in the center of the speaker.
  5. Promowide SP1790 Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Locate and remove the four screws under each of the pads near the power socket.
  6. Promowide SP1790 Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the bottom.
    • Do NOT pull out or damage wires.
  7. Promowide SP1790 Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the single motherboard screw.
  8. Promowide SP1790 Charging Port Replacement: Schritt 8, Bild 1 von 1
    • Remove both of the screws holding the power socket to the bottom chassis.
  9. Promowide SP1790 Charging Port Replacement: Schritt 9, Bild 1 von 1
    • Desolder and remove the old wire.
    • Insert the new wire and solder it into place.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 1,000
