Einleitung
All electrical components of the ProntoTec Axius tablet are connected to the motherboard. Water damage, dropping, and any other physical damage can cause the motherboard to short or malfunction; rendering the device unusable. This guide will highlight how to disconnect the motherboard from the other components of the device for replacement.
Was du brauchst
Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
Use pliers to pull the wire from the board
Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
Gently pull and remove the ribbon cables from the motherboard
Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
