Zum Hauptinhalt wechseln
ProntoTec Axius Screen Replacement
Was du brauchst
  1. ProntoTec Axius Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
    • Place the tablet face-up on a flat table
  2. ProntoTec Axius Screen Replacement: Schritt 2, Bild 1 von 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Screen Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove all of the yellow tape that is on the device with the spudger.
    • Be careful not to cut any wires that are under the tapes.
  5. ProntoTec Axius Screen Replacement: Schritt 5, Bild 1 von 2 ProntoTec Axius Screen Replacement: Schritt 5, Bild 2 von 2
    • Use the flat end of the spudger to gently pry the battery from the back of the screen.
  6. ProntoTec Axius Screen Replacement: Schritt 6, Bild 1 von 2 ProntoTec Axius Screen Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to lift all the ribbon cable clamps
    • Detach all three ribbon cables from the clamps
  7. ProntoTec Axius Screen Replacement: Schritt 7, Bild 1 von 3 ProntoTec Axius Screen Replacement: Schritt 7, Bild 2 von 3 ProntoTec Axius Screen Replacement: Schritt 7, Bild 3 von 3
    • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
  8. ProntoTec Axius Screen Replacement: Schritt 8, Bild 1 von 3 ProntoTec Axius Screen Replacement: Schritt 8, Bild 2 von 3 ProntoTec Axius Screen Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
    Kaufen
    • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
    • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
  9. ProntoTec Axius Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the orange tab from the back of the screen as shown in the picture
  10. ProntoTec Axius Screen Replacement: Schritt 10, Bild 1 von 2 ProntoTec Axius Screen Replacement: Schritt 10, Bild 2 von 2
    • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
Abschluss
Antonio Irons
441 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-3, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 264
