Einleitung
Like most electronics, after some time the battery life will not be like it used to be. One can tell if the flight of the gyro-copter does not last as long or if there is trouble charging. Replacing the battery pack is not difficult but will require some soldering skills.
Was du brauchst
Remove the two 5.0 mm Phillips #00 screws from the rotors.
The blades will fall off when the screws have been removed.
Push the front of the nose back towards the tail of the helicopter.
Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
Pull the battery off of the holder.
Cut each of the wires to the battery one at a time using a pair of wire cutters.
Once the wires are cut, strip and solder the wires connected to the Gyro-X to the wires of the new batter pack.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
