Einleitung
After rough flights the stabilizer beam may end up getting damaged. Without a working stabilizer beam, the gyro-copter will not fly as it should. The best way to fix this is by replacing the stabilizer beam completely.
Was du brauchst
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
Pull up on the stabilizer assembly to remove it completely from the drive shaft.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
