Was du brauchst
Tools necessary for task. Starting from the left to right Metal Spudyer Plastic opening tool Precision tweezer Point pen tool Driver with bit size J0
The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
You can directly locate and remove the camera component in the corner. Simply unscrew the piece and gently remove the tape wire.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
