Einleitung
This guide explains how to replace the Protocol Dronium III AP Camera.
Was du brauchst
Remove the eight (8) 5mm screws attaching the motor arms to the body using a JIS #00 screwdriver.
Remove the six (6) 5mm screws attaching the Body Cover to the Body of the drone using a JIS #00 screwdriver.
Remove the Body Cover.
Remove the two (2) 5mm screws attaching the Motherboard to the body of the drone using a JIS #00 screwdriver.
Lift the Motherboard off the mounting position.
Remove the tape covering the camera with the tweezers.
