Zum Hauptinhalt wechseln
Protocol Dronium Two HD Camera Replacement
Was du brauchst
  1. Protocol Dronium Two HD Camera Replacement, Landing Gear: Schritt 1, Bild 1 von 1
    • Turn device off by moving the selector switch to the left.
  2. Protocol Dronium Two HD Camera Replacement: Schritt 2, Bild 1 von 2 Protocol Dronium Two HD Camera Replacement: Schritt 2, Bild 2 von 2
    • Place one hand on the drone and carefully remove the landing gear with the other hand.
    • Be gentle as to not break off the studs on the landing gear.
  3. Protocol Dronium Two HD Camera Replacement, HD Camera: Schritt 3, Bild 1 von 2 Protocol Dronium Two HD Camera Replacement, HD Camera: Schritt 3, Bild 2 von 2
    • Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
  4. Protocol Dronium Two HD Camera Replacement: Schritt 4, Bild 1 von 2 Protocol Dronium Two HD Camera Replacement: Schritt 4, Bild 2 von 2
    • Push the battery cover away from the drone and carefully open it up.
  5. Protocol Dronium Two HD Camera Replacement: Schritt 5, Bild 1 von 2 Protocol Dronium Two HD Camera Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the two Phillips 5.35 mm screws holding the camera to the battery cover.
  6. Protocol Dronium Two HD Camera Replacement: Schritt 6, Bild 1 von 1
    • Close the battery cover by pulling it towards you. Then, gently pull the camera towards you, freeing it from the battery cover.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
William Tietz
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 219
