Zum Hauptinhalt wechseln
Protocol Dronium Two Rechargeable Battery Replacement
Was du brauchst
  1. Protocol Dronium Two Rechargeable Battery Replacement, Rechargeable Battery: Schritt 1, Bild 1 von 1
    • Turn the drone off by moving the selector switch to the left.
  2. Protocol Dronium Two Rechargeable Battery Replacement: Schritt 2, Bild 1 von 1
    • On the underside of the drone, gently pull the battery compartment away from the drone.
    • Press down on the camera as shown to get a better grip.
  3. Protocol Dronium Two Rechargeable Battery Replacement: Schritt 3, Bild 1 von 2 Protocol Dronium Two Rechargeable Battery Replacement: Schritt 3, Bild 2 von 2
    • If the power cable of the battery is connected to the drone, remove it by gently pulling it out.
  4. Protocol Dronium Two Rechargeable Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from its compartment by sliding it out away from the drone.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Edwin Brietz
557 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 442
