Zum Hauptinhalt wechseln
Protocol Galileo Stealth Housing Replacement
Was du brauchst
  1. Protocol Galileo Stealth Housing Replacement, Propeller: Schritt 1, Bild 1 von 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Housing Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Housing Replacement: Schritt 3, Bild 1 von 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Housing Replacement: Schritt 4, Bild 1 von 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Housing Replacement, Housing: Schritt 5, Bild 1 von 2 Protocol Galileo Stealth Housing Replacement, Housing: Schritt 5, Bild 2 von 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Housing Replacement: Schritt 6, Bild 1 von 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
Abschluss
UW Stout, Team S8-G4, Ogden Spring 2018 Mitglied von UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 128
