Einleitung
This guide will walk you through how to replace the light emitting diodes (LED) on the drone. Minimal tooling is required, but the risk of damaging the drone is greater then many of the other guides if each step is not followed and executed with extra care.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Separate the upper and lower housing units by lightly pulling the two housing units apart.
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
    • Remove 6mm Phillips #0 screw from the LED strip.
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
Abschluss
Matthew Selting
Mitglied seit 15.02.2018
411 Reputation
4 Anleitungen geschrieben
UW Stout, Team S8-G4, Ogden Spring 2018 Mitglied von UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 43
