Einleitung
This guide will walk you through how remove the drone motors from the lower housing. Minimal tooling is required; however, prerequisite steps are required. This guide is useful for replacing a motor that may be defective or damaged.
Was du brauchst
Remove the chrome shaft cover by lightly pulling it away from the drone.
Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
Remove the propeller stop from shaft by lightly pulling it away from the drone.
Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
Separate the upper and lower housing units by lightly pulling the two housing units apart.
Remove the 3 outer 8mm long Phillips #0 screws from the lower drone housing.
Remove the 2 inner 3 mm long Phillips #0 screws from the drone motor.
Remove the two 6mm long Phillips #0 screws from the lower motor cover located on the underside of the drone.
Unclip the wire plug by applying light pressure to the wire plug with the plastic opening tool, and remove the motor.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
