Einleitung
This guide will walk you through how to remove the motor propeller from the drone. This is a very simple process, and minimal tooling is required. This guide is useful for replacing blades that may have been damaged.
Was du brauchst
Remove the chrome shaft cover by lightly pulling it away from the drone.
Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
Remove the propeller stop from shaft by lightly pulling it away from the drone.
