Einleitung
Use this guide to access and replace the main circuit board of the Protocol Kaptur GPS drone.
You can also use this guide to replace the battery: Protocol Kaptur GPS Battery Replacement.
Was du brauchst
The battery is accessible through the back of the drone.
Press the tabs on both sides of the white stripe to pull the battery out.
Remove the screws starting with the three smaller ones on the top part of the battery.
Remove the three screws on the other side.
There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
Remove the two hidden screws at the bottom, and the white power button.
Unplug all the cords from the circuit boards.
Carefully slide the main body right off the arms.
Remove the four 4mm Phillips screws.
Desolder all cords on the circuit board, and pull the board up and out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
