Zum Hauptinhalt wechseln
Protocol Slipstream EVO Propeller blades Replacement
Was du brauchst
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: Schritt 1, Bild 1 von 1
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: Schritt 2, Bild 1 von 2 Protocol Slipstream EVO Propeller blades Replacement: Schritt 2, Bild 2 von 2
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: Schritt 3, Bild 1 von 3 Protocol Slipstream EVO Propeller blades Replacement: Schritt 3, Bild 2 von 3 Protocol Slipstream EVO Propeller blades Replacement: Schritt 3, Bild 3 von 3
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
Abschluss
Michael Dang
301 Reputation
3 Anleitungen geschrieben
UW Tacoma, Team S3-G3, Liner Spring 2017 Mitglied von UW Tacoma, Team S3-G3, Liner Spring 2017
UWT-LINER-S17S3G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 536
