Zum Hauptinhalt wechseln
Protocol Slipstream WiFi Propeller Replacement
Was du brauchst
  1. Protocol Slipstream WiFi Propeller Replacement, Propeller: Schritt 1, Bild 1 von 1
    • Remove the 4.5 mm Philips #00 screw that holds the propeller in place.
  2. Protocol Slipstream WiFi Propeller Replacement: Schritt 2, Bild 1 von 1
    • Lift the propeller off the device
    • Note: When sliding on the new propeller, make sure to align the groove on the propeller with the shaft of the gear. If aligned correctly the propeller should slide on smoothly.
    • There are two different propellers that go on the device. Each propeller has a 3 or 4 written on it. Be sure to replace the propeller with a new propeller with the matching number.
Abschluss
Bryan Chever
135 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 218
