Einleitung
This guide will show you the steps needed to remove the battery from the drone's controller. You will need to remove the battery cover using a phillips head screwdriver and remove the batteries
Was du brauchst
Using a Phillips #0 screwdriver, remove the screw connecting the battery cover to the controller.
Remove the battery cover from the controller.
Fast fertig!
Abschluss
