Zum Hauptinhalt wechseln
Protocol TerraCopter EVO Front Wheels Replacement
Was du brauchst
  1. Protocol TerraCopter EVO Front Wheels Replacement, Propellers: Schritt 1, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the four screws connecting the propellers to the device.
  2. Protocol TerraCopter EVO Front Wheels Replacement: Schritt 2, Bild 1 von 2 Protocol TerraCopter EVO Front Wheels Replacement: Schritt 2, Bild 2 von 2
    • Hold the propellers gently and pull the propellers out of the drone .
  3. Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: Schritt 3, Bild 1 von 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: Schritt 3, Bild 2 von 3 Protocol TerraCopter EVO Front Wheels Replacement, Front Wheels: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool or a spudger to separate the drone's cover from the body of the drone.
    • Remove the connector of the drone body and the back wheels using a plastic opening tool.
  4. Protocol TerraCopter EVO Front Wheels Replacement: Schritt 4, Bild 1 von 2 Protocol TerraCopter EVO Front Wheels Replacement: Schritt 4, Bild 2 von 2
    • Use the opening tool to separate the drone's body from the drone's shock absorber.
  5. Protocol TerraCopter EVO Front Wheels Replacement: Schritt 5, Bild 1 von 3 Protocol TerraCopter EVO Front Wheels Replacement: Schritt 5, Bild 2 von 3 Protocol TerraCopter EVO Front Wheels Replacement: Schritt 5, Bild 3 von 3
    • Hold the wheels gently then pull it out of the drone's lower board wheels connector.
    • Repeat the same step for the other front wheel.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 120
