Einleitung
This guide will demonstrate how to remove and replace one or more propellers on the Protocol Vento drone. You will need the small, silver prying tool that is included in the Protocol Vento drone kit.
Was du brauchst
Grasp the tail end of the drone where the lip of the battery protrudes.
Use a moderate amount of force to pry the propeller out of its base. The propeller should pop off.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
