Einleitung
This guide will show how to replace the propeller guards. You will only need a #0 Philips screwdriver for this guide.
Was du brauchst
Unscrew the four secondary screws using the Phillips #0 screwdriver.
If the screwdriver does not fit in the guard hole, lift and move the guard to the side and unscrew.
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
thank you i didn’t see the small part until i saw this
