Zum Hauptinhalt wechseln
Punkt MP02 Battery Replacement
Was du brauchst
  1. Punkt MP02 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Punkt MP02 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a SIM card eject tool to to eject and remove the SIM card tray on the side of the phone.
  2. Punkt MP02 Battery Replacement: Schritt 2, Bild 1 von 2 Punkt MP02 Battery Replacement: Schritt 2, Bild 2 von 2
    • The back panel is held on by glue and multiple tabs.
    • Slide a Jimmy into the seam between the back panel and the chassis.
    • Slide the Jimmy around the perimeter to release the back panel, with care not to damage the retaining clips.
    • Clean any old adhesive with a spudger and isopropyl alcohol, then apply new adhesive to the back panel before reinstalling it.
  3. Punkt MP02 Battery Replacement: Schritt 3, Bild 1 von 3 Punkt MP02 Battery Replacement: Schritt 3, Bild 2 von 3 Punkt MP02 Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips screwdriver to remove the two adjacent 3 mm Phillips screws.
  4. Punkt MP02 Battery Replacement: Schritt 4, Bild 1 von 3 Punkt MP02 Battery Replacement: Schritt 4, Bild 2 von 3 Punkt MP02 Battery Replacement: Schritt 4, Bild 3 von 3
    • Insert a Jimmy into the seam between the front and back case.
    • Slide the Jimmy around the perimeter while prying to separate the front and back case.
  5. Punkt MP02 Battery Replacement: Schritt 5, Bild 1 von 2 Punkt MP02 Battery Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to pry up and disconnect the battery press connector.
    • Make sure to pry under the connector itself and not on the board.
  6. Punkt MP02 Battery Replacement: Schritt 6, Bild 1 von 2 Punkt MP02 Battery Replacement: Schritt 6, Bild 2 von 2
    • Gently pry the battery off with the spudger tool.
    • Take care not to bend, warp, or puncture the battery during removal.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Elias Fischer
425 Reputation
3 Anleitungen geschrieben
University of Memphis, Team 1-3, Sneed Spring 2026 Mitglied von University of Memphis, Team 1-3, Sneed Spring 2026
UM-SNEED-S26S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 18
Letzte 30 Tage: 18
Insgesamt: 72
