Was du brauchst
Begin the process by using a PH00 Phillips screw driver.
Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
Eine weitere Person hat diese Anleitung absolviert.
