Was du brauchst
Begin the process by using a PH00 Phillips screw driver.
Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
Use the plastic opening pick in order to remove the battery from the tablet, and set it aside for the replacement.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
