Einleitung
This guide shows what's involved and the how-to in replacing the camera on the tablet device.
Was du brauchst
Begin the process by using a PH00 Phillips screw driver.
Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
Use the plastic opening pick and the Phillips screwdriver to remove the camera from its soldering on the motherboard, and set it aside to be replaced.
Fast fertig!
Abschluss
