Zum Hauptinhalt wechseln
QFX IT-437 Camera Assembly Replacement
Was du brauchst
  1. QFX IT-437 Camera Assembly Replacement, Camera Assembly: Schritt 1, Bild 1 von 1
    • Begin the process by using a PH00 Phillips screw driver.
    • Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
  2. QFX IT-437 Camera Assembly Replacement: Schritt 2, Bild 1 von 2 QFX IT-437 Camera Assembly Replacement: Schritt 2, Bild 2 von 2
    • Use the iFixit plastic opening tool to pry open the back of the tablet.
    • Do not remove the back case completely as tape has to be removed from the wires, and pulling the case apart can tear off the wires.
  3. QFX IT-437 Camera Assembly Replacement: Schritt 3, Bild 1 von 1
    • Use the spudger to unhinge the camera from its socket.
  4. QFX IT-437 Camera Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening pick and the Phillips screwdriver to remove the camera from its soldering on the motherboard, and set it aside to be replaced.
Abschluss
Douglas
482 Reputation
4 Anleitungen geschrieben
Pasco Hernando, Team 5-2, Prince Winter 2015 Mitglied von Pasco Hernando, Team 5-2, Prince Winter 2015
PHSC-PRINCE-W15S5G2
6 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 124
