Was du brauchst
Begin the process by using a PH00 Phillips screw driver.
Remove the two 1.2mm x 3mm screws at the bottom of the tablet.
In order to unseat the motherboard, use the Phillips PH00 screw driver bit to remove the three 1.2mm x 3mm screws.
Once the motherboard is loose, remove the tape above the SD card slot using an iFixit opening pick.
2 weitere Personen haben diese Anleitung absolviert.
