Was du brauchst
Locate the battery and remove it.
If you wish to replace the battery you can do so here.
Use the Phillips PH1 screwdriver to unscrew the five 4x2.5mm screws that hold the back cover.
After removing the panel and the battery, your tablet should look like this.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
