Zum Hauptinhalt wechseln
Quantum View 10.1 Battery Replacement
Was du brauchst
  1. Quantum View 10.1 Battery Replacement, Open Quantum View case: Schritt 1, Bild 1 von 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: Schritt 2, Bild 1 von 2 Quantum View 10.1 Battery Replacement, Removing the electrical tape and magnets.: Schritt 2, Bild 2 von 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Battery Replacement, Unhooking the battery: Schritt 3, Bild 1 von 2 Quantum View 10.1 Battery Replacement, Unhooking the battery: Schritt 3, Bild 2 von 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
Abschluss
Gateway Community College Team 1 BPC270 36301 Mitglied von Gateway Community College Team 1 BPC270 36301
Community
4 Mitglieder
7 Anleitungen geschrieben
3 Kommentare
How do I find a replacement battery?
Chris Clayton - Antwort
Seems finding the right battery is a problem
where can I find a replacement battery and screen for this i only have the motherboard lying around and i really want to repair it so i can access old data
aabel joby - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 881
