Zum Hauptinhalt wechseln
Quantum View 10.1 camera Replacement
Was du brauchst
  1. Quantum View 10.1 camera Replacement, Open Quantum View case: Schritt 1, Bild 1 von 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: Schritt 2, Bild 1 von 2 Quantum View 10.1 camera Replacement, Removing the electrical tape and magnets.: Schritt 2, Bild 2 von 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 camera Replacement, Unhooking the battery: Schritt 3, Bild 1 von 2 Quantum View 10.1 camera Replacement, Unhooking the battery: Schritt 3, Bild 2 von 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
    • Remove yellow plastic and carefully pull clip away from connection.
  4. Quantum View 10.1 camera Replacement, Remove camera clip: Schritt 5, Bild 1 von 2 Quantum View 10.1 camera Replacement, Remove camera clip: Schritt 5, Bild 2 von 2
    • Remove yellow tape.
    • Unclip ribbon connector.
  5. Quantum View 10.1 camera Replacement, Remove camera: Schritt 6, Bild 1 von 2 Quantum View 10.1 camera Replacement, Remove camera: Schritt 6, Bild 2 von 2
    • Unscrew plastic camera holder using a PH00 screwdriver bit.
    • Release the plastic holder tab and remove camera.
Abschluss
Gateway Community College Team 1 BPC270 36301 Mitglied von Gateway Community College Team 1 BPC270 36301
Community
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 155
