Einleitung
This is a step-by-step with photos that will show you how to replace your Quantum XTR05 pinion gear in your spinning fishing reel. This will ensure the functionality of your spinning reel and will help to mitigate a failure within the span of the reel's lifetime.
No outside tools are needed for the replacement process.
Choking hazard with small children present with small pieces.
Unscrew by turning the cap counter-clockwise until it is separated from the spinning reel.
Place the spool release and drag adjustment piece back onto the top of the pinion.
Screw the spool release and drag adjustment back into place in a clockwise direction until desired tension is achieved.
