Zum Hauptinhalt wechseln
Quiksilver The Fifty50 Back Panel Replacement
Was du brauchst
  1. Quiksilver The Fifty50 Back Panel Replacement, Strap: Schritt 1, Bild 1 von 2 Quiksilver The Fifty50 Back Panel Replacement, Strap: Schritt 1, Bild 2 von 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Back Panel Replacement: Schritt 2, Bild 1 von 2 Quiksilver The Fifty50 Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Back Panel Replacement, Back Panel: Schritt 3, Bild 1 von 2 Quiksilver The Fifty50 Back Panel Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Back Panel Replacement: Schritt 4, Bild 1 von 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
Abschluss
Sue Giske
622 Reputation
5 Anleitungen geschrieben
UW Tacoma, Team S1-G4, Liner Summer 2019 Mitglied von UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 198
