Zum Hauptinhalt wechseln
Quiksilver The Fifty50 Digital Battery Replacement
Was du brauchst
  1. Quiksilver The Fifty50 Digital Battery Replacement, Strap: Schritt 1, Bild 1 von 2 Quiksilver The Fifty50 Digital Battery Replacement, Strap: Schritt 1, Bild 2 von 2
    • Place the watch (face down) on a solid surface.
    • Carefully use the screwdriver and push in one side of the strap.
    • Slowly remove the strap by pushing back one of the hidden metallic holders for the strap.
    • If you are having difficulty trying to take off the strap, feel free to use a 3.5 flat head screw driver, or any kind of tool that make this step easier.
  2. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 2, Bild 1 von 2 Quiksilver The Fifty50 Digital Battery Replacement: Schritt 2, Bild 2 von 2
    • Gently pull the pin out of the strap.
    • Carefully handle the small metallic holder, as they are sharp and may be difficult to locate if lost.
  3. Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: Schritt 3, Bild 1 von 2 Quiksilver The Fifty50 Digital Battery Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Remove the four 1.1 mm screws holding the back panel in place using the Phillips #00 screwdriver.
  4. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 4, Bild 1 von 1
    • Carefully separate the panel off of the watch.
    • Careful not to lose the four 1.1 mm screw or else the back panel will not be able to put back.
  5. Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: Schritt 5, Bild 1 von 2 Quiksilver The Fifty50 Digital Battery Replacement, Analog Battery: Schritt 5, Bild 2 von 2
    • Carefully lift the white plastic circular out of the watch.
  6. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 6, Bild 1 von 3 Quiksilver The Fifty50 Digital Battery Replacement: Schritt 6, Bild 2 von 3 Quiksilver The Fifty50 Digital Battery Replacement: Schritt 6, Bild 3 von 3
    • Remove the four 1.1 mm screws located on the metallic holder using the Phillips #00 screwdriver.
  7. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 7, Bild 1 von 3 Quiksilver The Fifty50 Digital Battery Replacement: Schritt 7, Bild 2 von 3 Quiksilver The Fifty50 Digital Battery Replacement: Schritt 7, Bild 3 von 3
    • Remove the large circular Analog battery.
  8. Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: Schritt 8, Bild 1 von 2 Quiksilver The Fifty50 Digital Battery Replacement, Circuit Board: Schritt 8, Bild 2 von 2
    • Using the Phillips #00 screwdriver, remove the two 1 mm screws holding the circuit board to the device.
  9. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the green circular chip using a pair of tweezers.
  10. Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: Schritt 10, Bild 1 von 2 Quiksilver The Fifty50 Digital Battery Replacement, Digital Battery: Schritt 10, Bild 2 von 2
    • Using the Phillips #00 screwdriver, remove the 1.1 mm screw that is holding the digital battery holder in place.
  11. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 11, Bild 1 von 1
    • Use the magnetic pick-up tool to remove the small screw.
    • Careful to not lose this screw because it is crucial for putting the watch back.
  12. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 12, Bild 1 von 1
    • Lift up the battery holder.
  13. Quiksilver The Fifty50 Digital Battery Replacement: Schritt 13, Bild 1 von 1
    • Remove the digital battery from the socket.
Abschluss
Sue Giske
622 Reputation
5 Anleitungen geschrieben
UW Tacoma, Team S1-G4, Liner Summer 2019 Mitglied von UW Tacoma, Team S1-G4, Liner Summer 2019
UWT-LINER-SU19S1G4
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 1,577
