Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove all wires then flip the laptop
    • Remove all wires then flip the laptop
  2. Remove the battery Remove the battery
    • Remove the battery
  3. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  4. Flip the Laptop, and unscrew the RAM cover. Flip the Laptop, and unscrew the RAM cover. Flip the Laptop, and unscrew the RAM cover.
    • Flip the Laptop, and unscrew the RAM cover.
  5. Unlock the RAM by pulling the locks outward. You'll know if its unlocked if it flips up in 45 degrees.
    • Unlock the RAM by pulling the locks outward.
    • You'll know if its unlocked if it flips up in 45 degrees.
  6. Pull the outer RAM. Repeat Step 4 and 5 for the other RAM. When returning, put the RAM back in at 45 degree angle, NOT 90 degree angle.
    • Pull the outer RAM. Repeat Step 4 and 5 for the other RAM.
    • When returning, put the RAM back in at 45 degree angle, NOT 90 degree angle.
Abschluss
trickster
2.019 Reputation
11 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 898
