Zum Hauptinhalt wechseln
RCA 10 Viking Pro RCT6K03W13 Battery Replacement
Was du brauchst
  1. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: Schritt 1, Bild 1 von 3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: Schritt 1, Bild 2 von 3 RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Backplate: Schritt 1, Bild 3 von 3
    • Remove the three Phillips #00 screws at the bottom of the device.
  2. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 2, Bild 1 von 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the two Phillips #00 screws to the left and right of the keyboard connector.
  3. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 3, Bild 1 von 1
    • Pull on one of the bottom corners to begin to pull off the back plate.
  4. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 4, Bild 1 von 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 4, Bild 2 von 2
    • Work around the outside of the chassis, using the spudger to pry the backplate off.
    • After doing this for about half the device, the backplate should pop right off.
  5. RCA 10 Viking Pro RCT6K03W13 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Remove the tape over the connectors on the motherboard and other side of the battery.
  6. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the red and black keyboard wires connecting the battery to the motherboard.
  7. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
  8. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 8, Bild 1 von 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 8, Bild 2 von 2
    • Remove the cable over the battery connecting the motherboard and the power connector.
    • Flip up the black clamp and pull the cable out.
  9. RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 9, Bild 1 von 2 RCA 10 Viking Pro RCT6K03W13 Battery Replacement: Schritt 9, Bild 2 von 2
    • Pull out battery. It is taped to the device so it is safe to pull out.
    • Look for damage to the battery. If damaged, make sure to not get any acid on your fingers.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ryan Wickett
632 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G8, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G8, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G8
3 Mitglieder
4 Anleitungen geschrieben
4 Kommentare
Where can I get the battery for this?
Justin - Antwort
You can get a battery from Amazon or Walmart.com your wellcome ?
GLENDA Vandergrift -
How much voltage should the battery put out in order for the tablet to turn on?
Jesus Rios - Antwort
How much
How much
jennylyne_08 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 39
Insgesamt: 3,058
