Einleitung
If your television emits sound but does not display visuals and all TV the settings are correct, this guide explains how to replace a faulty motherboard.
The capacitors in televisions can store a potentially fatal charge for several months after the TV is unplugged and must be properly discharged to safely handle the motherboard.
Was du brauchst
Lay the TV flat with the screen facing down.
Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
Remove the stand by lifting it away from the TV's backing.
Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
Position the television to where the back panel is resting on the table and the screen is vertical.
Peel the tape covering the ribbon cable horizontally.
Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
Remove the screen to isolate the back panel.
Identify the motherboard in the rear casing.
Remove the ground cable from the motherboard by gently lifting it up as shown.
Remove the six 6mm Phillips #2 screws from the perimeter of the motherboard.
Remove the motherboard by gripping the rubber stopper as shown and lifting the motherboard up out of its plastic housing.
Carefully flip the motherboard over and locate the nineteen capacitors.
Notice the six cables attached to the motherboard. Pull on each cable connector with moderate to heavy force to remove them.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
